First Build Started http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=50869 |
Author: | banjopicks [ Fri Aug 03, 2018 8:20 am ] |
Post subject: | First Build Started |
Finally cut some wood for this project. The birch ply for the mold cut into ~12" X 24". Need to buy one more layer today and cut that. 3 layers is enough right? I'm going to copy the plan on the printer at work to get the outline to glue on to the first piece which will become the template for the rest. They say on the plan "Reference Only Use dimensions" but there aren't any dimensions for the body to check against. Can someone give me those.? It's the StewMac plan for a dread. Here's my stuff for your discerning eyes. Attachment: AQll2.jpg Attachment: All1.jpg Attachment: Brace2.jpg Attachment: BackAndSides.jpg Attachment: Back.jpg This is a close up of the mineral deposits I'll be dealing with. These are all Martin seconds EIR back and sides. Attachment: BackMineralDeposits.jpg Attachment: Back2.jpg Attachment: MoldMaterial.jpg
Author: | Michaeldc [ Fri Aug 03, 2018 8:32 am ] |
Post subject: | Re: First Build Started |
This is an addictive pursuit.. It's not too late to step away... Here's a thread on dealing with mineral deposits that happened a few weeks ago. viewtopic.php?f=10101&t=50643 Best, M |
Author: | Freeman [ Fri Aug 03, 2018 2:29 pm ] |
banjopicks wrote: . They say on the plan "Reference Only Use dimensions" but there aren't any dimensions for the body to check against. Can someone give me those.? It's the StewMac plan for a dread. The plans may be scaled. They will give you critical dimensions on the plans - scale length, fret spacing, neck dimensions - those should be adhered to. Everything else can be scaled. Remember that these are generic plans - there are many models and configurations of dreadnaughts and you plans may not be the exact model that you are emulating. However for a first guitar it will be good enough. |
Author: | banjopicks [ Fri Aug 03, 2018 2:33 pm ] |
I guess as long as it fits in a case when I'm done. I have a D28 case I can check it in at my daughters house. |
Author: | J De Rocher [ Fri Aug 03, 2018 11:40 pm ] |
Author: | banjopicks [ Thu Aug 09, 2018 10:45 am ] |
I was originally planning on bending my sides on my SM bender but after cutting the outside mold and seeing that I have 80% of a fox bender sitting on my bench, I guess I need a heat blanket now ![]() |
Author: | Freeman [ Thu Aug 09, 2018 11:09 am ] |
Can't help with the cheap blanket - I bought mine from John Hall (Bluescreek) along with the controller and timer and it has served me well for a couple dozen guitars. I think you will find both are helpful, you bring your sides up to temperature then back off the controller to maintain the desired heat for an amount of time before shutting it off. ![]() ![]() John has a great set of tutorials on his web site that I would suggest reviewing before you bend your sides. |
Author: | Colin North [ Thu Aug 09, 2018 2:31 pm ] |
banjopicks wrote: I was originally planning on bending my sides on my SM bender but after cutting the outside mold and seeing that I have 80% of a fox bender sitting on my bench, I guess I need a heat blanket now ![]() I use a Keenvo 1200 watt blanket (seems well made, with my own controller) and I would NOT advise leaving it at max for long at all - it'll catch fire before you can dial the fire brigade. Seriously, at least use a router speed controller or to make one for $20 or so, see http://www.luthiersforum.com/forum/viewtopic.php?f=10117&t=47715&p=630887&hilit=+temerature#p630887 |
Author: | Freeman [ Thu Aug 09, 2018 3:59 pm ] |
Don't forget too that you can bend on a simple hot pipe and clamp against the "inside" form. I still use my hot pipes a lot for one of a kind bends and pieces of bindings |
Author: | whiskywill [ Fri Aug 10, 2018 11:05 am ] |
banjopicks wrote: I'm not concerned with the controllers, I use a Chinese heat blanket with one of these. https://www.aliexpress.com/item/Digital ... autifyAB=0 Works really well. |
Author: | Freeman [ Fri Aug 10, 2018 11:17 am ] |
whiskywill wrote: banjopicks wrote: I'm not concerned with the controllers, I use a Chinese heat blanket with one of these. Works really well. I assume thats a thermocouple coiled up in the picture - how do you embed that in your blanket sandwich? I like the idea of having feedback from the wood being heated. |
Author: | Colin North [ Fri Aug 10, 2018 5:49 pm ] |
I took the soldered wire sensor out of the casing and gently tapped it flat (mine's virtually the same) In use it sits between the wood and the paper. |
Author: | Dave m2 [ Sun Aug 12, 2018 11:14 am ] |
I use a Keenovo blanket with built in controller. Works very well. I see it goes for about £60 in the UK but bound to be available elsewhere. Dave |
